JD 3130 with loader
Harry
11-14-2003 19:17:07
I'm getting a new toy this weekend. 1985 JD3130 with loader. rebuilted motor, very good shape. Anything I need to check before I start using it. I know nothing about this size and model. What do I have to do to get it use catI implements. what size shredder do I need?
Thanks in advance for any tips and advice!!
david val
11-15-2003 00:34:19
 Re: JD 3130 with loader in reply to Harry, 11-14-2003 19:17:07
the last mannheim built 3130 came out at 1980, their replacement were 3140.
are you sure it's 3130? check the tag. maybe its a suoth american or other non mannheim model.
once your'e sure of the model get a om. much good info there. replace hydralic filter. oil in filter cup should be clean and clear.
david
david val
11-15-2003 00:29:25
anyway, as already posted, good sound tractors. a weak point is the dry clutch, especially at hard pulling jobs.
david
buickanddeere
11-14-2003 20:40:26
What serial number? The late 3130's were excellent, the early 3130 units had some transmission problems.
doug@upr
11-15-2003 14:21:16
 Re: Re: JD 3130 with loader in reply to buickanddeere, 11-14-2003 20:40:26
for the most part the 3130 was a good model tractor though if there was a problem that was common with them it was in the hydraulics, and many people have spent alot of money on them with no luck with fixing them, usually if the hydraulic become weak or they begin to heat up check your steering column for cracks of sometime the rockshaft cover will develope a crack also which will create heat and lose hydr. supply.
also the hi=lo shift system was suspect to have problems, but that was usaully as a result of poor hydr.
