2040 question for the JD experts
Brian
12-20-2000 17:03:56
I have a friend that has a 2040 JD and says his pto lever got hard to work and now it will not disengauge the pto. Can anyone tell me if it has a indep. or live pto and what may be the problem with it . Any help would be greatly appreciated.
Thanks Brian
L.C.
12-22-2000 18:24:54
 Re: 2040 question for the JD experts in reply to Brian, 12-20-2000 17:03:56
If the PTO turns only when the wheels are turning, then it's live. If the PTO turns independently of the wheels, then it's an independent PTO.
Also, if pushing the cluth pedal in halfway stops the tractor but not the PTO, then it's independent PTO.
HTH.
RayE
12-22-2000 19:19:15
 Re: Re: 2040 question for the JD experts in reply to L.C., 12-22-2000 18:24:54
The clutch has nothing to do with an independent
pto.It has a seperate lever,(between the gear
shifts) that is hydraulically operated so you
can turn the pto on and off without using the
clutch.This was a factory option.The standard
LIVE pto works off the clutch.Push the pedal
half way down,tractor stops,pto keeps running.
Push the clutch all the way down and both the
pto and tractor will stop.
ROBERT
12-22-2000 23:05:02
 Re: Re: Re: 2040 question for the JD experts in reply to RayE, 12-22-2000 19:19:15
IF the pto only turnes wine the wheels are turning
that is called a tran driven pto now that we have told you all there is to know about pto's which dose your frind have,
ROBERT
ROBERT
12-21-2000 18:35:56
you tell use dose he pull up on a knob betwen
the gear shifters or move a leve on the side of the tran case with the clutch pushed all the way down.
ROBERT
RayE
12-21-2000 11:39:34
You could get either on a 2040,The independent
was optional.
For Ray E I know but which one does this tractor have
12-21-2000 06:20:34
I know but which one does a 2040 have?
RayE
12-21-2000 04:06:56
Live pto is on the clutch,Independent has a seperate lever between the gearshifts.
Gman
12-20-2000 17:29:24
Brian I'm by far an expert,my neighbor had a 2040 pto shift lever got floppy and part of the linkage came apart and fell down in transmission so warn your neighbor to open it up and get that leakage out of the botton before he damages his transmission,my neighbors had a little pin to come out. Gman
