Rings for 70 All fuel?
Justin
12-18-2000 20:26:40
Where can I find rings for .090 over cast 70 All Fuel pistons?? Will my local JD dealer have them? Thanks,
Justin
Butch
12-19-2000 07:10:33
 Re: Rings for 70 All fuel? in reply to Justin, 12-18-2000 20:26:40
Hastings probably has what you need. You can't buy from them direct, but if you call or E-mail they will let you know if they can supply the rings and give you the name of the closest dealer. Their web site has an online catalog by model and by bore sizes.
Mike Aylward
12-19-2000 06:35:53
Justin, your dealer won't likely have these. You will probably have to go the aftermarket route. The 70 All-Fuel shares the same bore as a G, so G rings should work, assuming the ring widths are the same. Hope this helps. Mike
