JD 50 thermostat
Jack
12-15-2000 07:14:18
Where is the thermostat located on the JD 50?
JDyer
12-15-2000 18:32:02
 Re: JD 50 thermostat in reply to Jack, 12-15-2000 07:14:18
Jack, I found your spark plug covers for your 50, if you will Email me your mailing address, I will send them to you, Thanks Johnny Dyer.
Bill E. Parts book info.
12-15-2000 08:27:23
Jack, Up to serial# 5016615, there was no thermostat. the tractor had autoshutters. serial # 5016616 and up had a pressure cooling system. 5016616- 5029199 had the thermostat above the block and 5029200+ located its thermostat up by the radiator. This info. is located in parts book "PC-264". LP gas tractors are different. hope this helps!
bill
Charles
12-15-2000 13:32:52
 Re: Re: JD 50 thermostat in reply to Bill E. Parts book info., 12-15-2000 08:27:23
"Up to serial# 5016615, there was no thermostat. the tractor had autoshutters."
Well, there certainly is a thermostat on my early 50 #5005773, it's what operates the shutters! (OK, I know, it does not restrict fluid flow like a modern inline thermostat). It is located in the bottom radiator tank on the front side. NLA from Deere but I got one new in the box from another dealer they located for me.
Pete Bristol
01-08-2005 09:46:12
 Re: Re: Re: JD 50 thermostat in reply to Charles, 12-15-2000 13:32:52
I have a functional thermostat but my shutters have rusted and broken so bad I need new ones. Any ideas on where to find them? I mostly run in spring summer and fall... do I need them?
Thanks
Bill E.
12-15-2000 07:35:24
Jack, the answer depends on the serial #. Late models had the thermostat up near the radiator, on the upper pipe. Early models had it right above the block. Someone with a parts book can give you a better definition on serial # breaks. There were auto shutters early, also. Not sure if they had thermostats.??
Bill
