JD A serial #
need help
12-10-2000 09:17:24
I don't have a serial # plate on the styled A i just bought . Is there a number stamped any were ? Or how do I go about finding out what year it is? Thanks Mike
Mike Aylward
12-10-2000 16:09:51
 Re: JD A serial # in reply to need help, 12-10-2000 09:17:24
If you can give us some of the numbers off of the major castings we can get you a range of how old your tractor is. This will be helpful if you need to order parts. Hope this helps. Mike
rollo
12-10-2000 15:21:10
If you describe the key characteristics of the tractor (eg. battery box or not) someone can probably put you within a range of years, but the serial nomber is only in one place - on the tag. You might try to take the serial number of the magneto and see if you can use that to date the tractor. Ditto for thr powertrol or power lift serial no.
gordon
12-10-2000 13:15:51
Go to the serial number section under Research & Info in the left column on this page.
