Sealing Heli-Coil Threads in Head
Ken Reese
12-10-2000 07:10:51
When the head of my 1950 "B" was worked on, the machine shop installed three Heli-Coils in the manifold stud holes. All three holes are exposed to the water jacket below.
Loctite Tech. Support recommended Loctite 246, a hi-temp, medium strength thread locker/sealant which I have used in the installation of the manifold studs.
I feel that the Loctite will seal fine between the stud threads and the Heli-Coil. My concern is sealing between the new tapped threads(outside) and the Heli-Coils.
Note that the studs have interference threads (blunted/squared off) and fit extremely tight. That tightness may create sufficient pressure on the Heli-Coils to seal between the new outer threads and the coil itself. Also, the threadlocker/sealant may penetrate enough to provide a seal.
Has anyone had experience with this situation? Any opinions or suggestions?
Another question. What temperature does the manifold reach at its highest?
Thanks,
Ken Reese
E-mail: [email protected]
ROBERT
12-10-2000 17:38:25
 Re: Sealing Heli-Coil Threads in Head in reply to Ken Reese, 12-10-2000 07:10:51
sounds to me that the treads on the studs are no good,Loctite make some very good stuff and shoud work.
ROBERT
Larry Entenman
12-10-2000 16:26:54
I had that problem,used Bars leak,had to get it good and warm several times
Mike Aylward
12-10-2000 15:36:42
Ken, I have run into this before, and the Loctite will work fine on the Heli-Coil threads. I normally use Permatex #3 on the manifold bolt threads. Unless you want 100% originality (which I'm sure you probably do), I install bolts instead of studs, so if you have to take off the manifold you can without it being such a big project. Hope this helps. Mike
