All fuel manifold?
brian
12-09-2000 20:45:52
i have a 42 A that i have been restoring for 2 years and i have been tracking down as many nos parts as posible, well i found a set of .45 over all fuel pistons and im ready to go back with the engine but i dont know if my manifold is an all fuel or not. how can i tell the numbers are worn to where you cant read them please help thanks alot brian.
G Taylor gasoline pistons better
12-10-2000 19:23:35
 Re: all fuel manifold? in reply to brian, 12-09-2000 20:45:52
Gasoline now costs about the same as #2 diesel and makes for better drivability, less plug fouling,oil dilution and ring wash down. For idling around at parades gasoline pistons and an all fuel manifold combination will keep the plugs from fouling & burn less fuel while running on gasoline. For a working tractor gasoline pistons & a cold gasoline manifold will work best.
Bill {Antique Acres}
12-10-2000 03:22:59
Unless you are planning on running something other than gasoline, it will not make a difference. A all fuel manifold is kind all enclosed looking. There is metal completely surrounding the intake, unlike the Heisler manifold where the intake pipe goes straight back and down and is exposed all around. The all fuel had to be enclosed so it would preheat the fuel in order to help it burn. They are hard to explain what they look like. Someone correct me if I am wrong. Bill {Antique Acres}
