4 cylinder tractor engines, were they 8 cylinder engines cut in half?
gary
12-07-2000 08:32:02
I read recently where at least one tractor manufacturer used 1/2 of an 8 cylinder engine to make their early 4 cylinder engines. Can anyone supply more info about his. Which manufacturers did this, and who supplied the 8 cylinder engines? I know International did this on their Scout in early models, but his is the first I've heard about this concerning tractors.
This is just a matter of curiosity more than anything.
Bill
12-08-2000 02:29:53
 Re: 4 cylinder tractor engines, were they 8 cylinder engines cut in half? in reply to gary, 12-07-2000 08:32:02
Gary, Without digging out the book, my reference comes from the Ford tractor line up. The development of their engines went roughly like the following. The flat head v-8 was basically two 4's arranged together over a common crankshaft. Each bank had its own water pump and mag. When developing the 9n engine, desiners/engineers looked to existing production to share parts,reduce number of different parts, etc. this was part of Henry Ford's mass production ideas. The four cylinder engine came from the V-8 with changes to make it fit the tractor. This should get you started. the details may vary, but it's a start. There maybe others. Hope this helps. bill
Plant doctor
12-08-2000 04:53:45
 Re: Re: 4 cylinder tractor engines, were they 8 cylinder engines cut in half? in reply to Bill, 12-08-2000 02:29:53
Gary: Now that you said it I remember it. The flat head ford 4 cyl tractor shared parts with the ford car or truck V8. I think the pistons, rods, and some valve components were shared. Rod and main bearings were also shared, but only from certain models.
RayP
12-07-2000 18:06:53
If the V8 engine had separate blocks for each side, it might have been possible to attach block and head to a new crankcase. Much like an aircraft engine in a light plane, or a Corvair engine, which had separate "jugs" for each cylinder. But to "saw in half" a V8 would be a difficult if not impossible. Don't think that I've ever seen an automotive engine that would lend itself to "halving".
Gary
12-07-2000 18:48:03
 Re: Re: 4 cylinder tractor engines, were they 8 cylinder engines cut in half? in reply to RayP, 12-07-2000 18:06:53
Ray,
I am a little out of my league here, but I almost think they were referring to a "straight 8" rather than a V-8 engine. I read this in an Antique Tractor Book, while browsing in a bookstore. I will return to the store and try to get more details, and make sure that this information didn't just seep into my brain while I was asleep. If I am not mistaken, they mentioned more than one kind of tractor manufacturer did this. I will let you know one way or another. (Ironically, I have done some extensive searching on the internet and haven't found any support for this. I thought I would get a definitive answer on the board here, and am a little surprised that you are the only one who has responded.)
Dick B
12-08-2000 09:54:25
 Re: Re: Re: 4 cylinder tractor engines, were they 8 cylinder engines cut in half? in reply to Gary, 12-07-2000 18:48:03
The first Pontiac Tempest 4 cyl motors were, if I'm not mistaken, based on their V-8s. This was back in '61.
