49 'B axel shaft leaks oil
john
12-06-2000 14:55:11
I've heard that the rear axel oil seals for the late B's are on the inside of the axel casting. What is the best procedure to get to them and replace them? Thanks.
Gman
12-06-2000 22:54:42
 Re: 49 'B axel shaft leaks oil in reply to john, 12-06-2000 14:55:11
John remove the rockshaft housing loosen big cast nut enough where the threads want be damaged when you put wedge in between nuts. Take a hammer and drive wedge in between big cast nuts this will push axle out,remove bull gear and pull axle all the way out then you can take a bar and knock out the old oil seal then reinstall new seal. hope this helps Gman
