JD 445 Garden Tractor
IaDan
12-05-2000 08:46:10
I have a newer 445 garden tractor that I had to jump start yesterday. I let it run for about 1/2 hour. As I was puting it away, I happened to turn on the headlights and the tractor died. I have not cleaned the posts, could this be the problem? Is the battery shot or is there something more serious going on? Any help would be appreciated. DTR
Frank
12-05-2000 17:28:09
 Re: JD 445 Garden Tractor in reply to IaDan, 12-05-2000 08:46:10
Sounds like your battery is shot, or needs a long slow charge. When you turned on the headlights they took the juice that had been going to the ignition. I'd try charging the battery, but I wouldn't bet on it working.
Good Luck.
JDGnut-Try This... heheee
12-05-2000 17:43:41
 Re: Re: JD 445 Garden Tractor in reply to Frank, 12-05-2000 17:28:09
third party image
How about doing this to your 445.. heheee... We use this 425 to promote our Ag Tech program...
Sound like what was stated by someone else is your problem.. Either your battery is bad, or it is not getting a good connection.. like U said try cleaning the posts first.. and maybe charge the battery... Good luck...
JDGnut
