DLTX-53 Idle passage sizes
Mike Whitman
12-04-2000 07:40:44
I am in the process of re-building my DLTX-53 (1946 Model A All-Fuel). According to Robert's Carb Repair (and many others), #40 and #53 drill bit sizes are appropriate for the idle passage cleaning. My carb has obviously been recently redone (came apart too easliy and I can shine a light through the passages and they are all clean and smooth)yet I can't put a #53 or #40 drill bit through the appropriate idle passages. It's possible the previous "rebuilder" used the wrong size bits but it seems strange that this person did it for both sizes (#40 and #3).
I just wanted to confirm that #40 and #53 are appropriate for the DLTX-53 before I drill the passages bigger.
Thanks,
Mike
Cam
12-04-2000 11:01:02
 Re: DLTX-53 Idle passage sizes in reply to Mike Whitman, 12-04-2000 07:40:44
You have the correct size bits listed, the #40 and #53 wire gauge bits. It is possible that someone used a standard fraction size that was more available locally. The 3/32" bit is .0938 inches, while the #40 is .098 inches diameter. Around here, you can't find 6 inch-long wire gauge bits, and is tough enough finding the shorter length bits. Something to look out for: I just did my B carb and used the #40 on the top vertical passage. I got in a ways, and the passage started gripping the bit. Advance the bit just a little at a time. I had nightmares of the bit breaking off inside. Bad news. I was more careful with the horizontal passage. I am waiting delivery from Robert's repair for some parts now, and then I should be in business again. Good luck.
Mike Whitman
12-05-2000 05:20:44
 Re: Re: DLTX-53 Idle passage sizes in reply to Cam, 12-04-2000 11:01:02
CAM,
You were right, a 3/32" bit fits right into the larger 2 of the 3 passages. Do you know off-hand what the closest fractional size would be to bit #53 ?
Thanks again,
Mike
Cam
12-05-2000 09:03:17
 Re: Re: Re: DLTX-53 Idle passage sizes in reply to Mike Whitman, 12-05-2000 05:20:44
Mike
Looking in my handy-dandy Pocket Reference from Thomas Glover, the decimal equivilent of a #53 drill is .0595 inches. This is smaller than a 1/16 inch drill, which is .0625 inches. A 7/128 inch size is .0547 inches. I was able to use a standard length #53 and a pliers to clean out the secret passage. I got that bit at the local True Value Hardware. Luckily it was just a bit clogged. I would not use larger sizes for the secret passage. Size on that one may be critical.
Cam
Mike Whitman
12-05-2000 11:53:31
 Re: Re: Re: Re: DLTX-53 Idle passage sizes in reply to Cam, 12-05-2000 09:03:17
Cam,
Thanks for the replies.
I bought both a #40 and #53(Standard length) at my local ACE Hardware with the intention of using them only as guides to let me know if the passages needed to be drilled out. When I attempted this and saw that the passages were "sparking clean" but the wrong size, I became puzzled and wondered if the sizes were different among different DLTX carbs. But, I think I have concluded that whoever overhauled this carb before probably just used "fractional" drill bits. Fortunately there "err'd" on the small side and the holes are smaller than they should be.
Mike
