JD M PTO Shaft
swf
12-03-2000 16:17:49
There must be a trick to getting the PTO shaft out the transmission case of a 1947 M. The transmission is on the table, but I feel pretty stupid in that it's not apparent how the PTO shaft comes out. Must have to pull bearings off first??!!!
clooney
12-03-2000 17:27:43
 Re: JD M PTO Shaft in reply to swf, 12-03-2000 16:17:49
Swf, it has been a while since I have been in an M, so if better advise comes along go with it. If I remember correctly, you have to bump the shaft to the front to pop the front bearing race out & the shaft out of the rear bearing, then the shaft comes out the front. I think to remove the counter shaft cluster gear you will have to pull the output shaft on the M & early 40.
