51 A Compression Gearing?
Phil
12-02-2000 09:26:17
Does anyone know where I can find the ground speed of the gears (I know that the 51 A has a creeper low). And I want to know the compression ratio. Thanks
Pappy (Correction)
12-02-2000 09:39:22
 Re: 51 A Compression Gearing? in reply to Phil, 12-02-2000 09:26:17
Correction: That's "Operator's Manual", Pub. OM-R2002 JD
Pappy
12-02-2000 09:36:24
Taken from the opoerating manual: First Gear: 1.5 MPH Second Gear: 2.5 MPH Third Gear: 3.5 MPH Fourth Gear: 4.5 MPH Fifth Gear: 6.25 MPH Sixth Gear: 11.00 MPH Reverse: 3.0 MPH
Compression Ratio: Gas Burner: 5.60 to 1 All-fuel: 4.50 to 1
Maximum engine speed is 1080 RPM with no load.
Phil
12-02-2000 10:00:24
 Re: Re: 51 A Compression Gearing? in reply to Pappy, 12-02-2000 09:36:24
Pappy, thanks, just what I needed. My older JD goes 2.75 in 1st. Looks like 2nd gear would be about right for a Sled Pull with a 51 A. The tractor would need a lot of added weight to effectively use 1st gear.
