4010 JD Stuck engine
Keith
12-01-2000 17:07:06
Engine was running rough. I shut it down, now I can't turn the engine over. Starter was replaced, also new batterys,Even tried to rotate engine with a screw driver in the starter hole no luck.It seems like the engine is stuck.Please help.
Keith
12-12-2000 16:00:42
 Re: 4010 JD Stuck engine in reply to Keith, 12-01-2000 17:07:06
Thank you twopop &49g for the info I will start in that direction.
twopop
12-01-2000 17:28:52
gas or diesel.try to turn it backwards,but probability is you spun a bearing on the crank and now its locked tight to the crank
49g
12-02-2000 14:48:21
 Re: Re: 4010 JD Stuck engine in reply to twopop, 12-01-2000 17:28:52
If it`s diesel you might have stuck a piston to a sleeve. That would explain why it`s was running rough. Best of luck whatever it turns out to be! Scott
