JD 4020 Starter problem 12V System
Frank
11-13-2003 18:48:50
Hi 4020 Diesel. Problem with starter. Turn the key starts ,no problem. Next time turn key, nothing happens, don't hear the solinoids click and oil and battery lights don't come on, New batteries,cables cleaned, starter checks out OK. Can be started by going to the solinoid. Any ideas .Thanks Frank
mike francis
11-14-2003 20:27:26
 Re: JD 4020 Starter problem 12V System in reply to Frank, 11-13-2003 18:48:50
have you got it fixed yet ? let us know just curious.
Frank
11-14-2003 12:01:32
Hi . I guess I should of given more imfo . This is a standard shift 1970 4020 Diesel. Starts with the key and stops with the key, no button . Have tried anew switch with no luck.still the same,starts simetimes. Was wandering if it could be in one of the cut out fuses. Frank
WTW (Long Post)
11-14-2003 15:08:02
 Re: Re: JD 4020 Starter problem 12V System in reply to Frank , 11-14-2003 12:01:32
Frank, Now that I know what we are working on I will try to help some more. For sure your problem is intermittent and the best time to find it (of course) is when the problem is present other wise test may not reveal it. If you turn your key on and there is no dash lights that tells me the key switch is not getting power to it. Trace power flow with a 12 volt test light in the order given until you locate the area of concern. While making these checks leave the key switch on as the problem may show up when moving wiring and it will be revealed. Start at the starter solenoid terminal where the battery cable is connected as power will be present there as you said starter will crank if bypassed. This also will tell you your test light is working. The next place to check is the circuit breaker located above starter inside metal frame box behind left side panel with starter relay. May require removing the two 3/8" bolt to gain access. Check both at the wire terminal end and the circuit breaker studs, this will tell you that the connection at the breaker is good. I have seen this connection get rusty and fail open. If OK the next place to check is at the back of the alternator. Power should be present at the large output terminal of the alternator. This is another problem area as power flows to and from the alternator and the connection at the alternator fails. There is two heavy wires at this output terminal that are crimped into one eyelet that will vibrate loose and lose connection. Lightly tug on both these heavy large wires to ensure they are tight in connection. If OK the next place to check for power is where this heavy wire / circuit come to the circuit breaker panel located under the dash cowl on the left side of tractor. You will see this heavy wire that comes through the fire wall that hooks to and supplies the breakers. Check for power where wire connects to breakers. If power is not present, there is a single rubber booted connector located on the front side of fire wall that may be the cause. Pull apart connector and check to see if power is present at the hot side of connector, if not back up to alternator connection as that is where power comes from. If power is present at breakers, look for the inline fuse hooked to one of the breakers, check for power to and from this special slow burn fuse. This is the last fused place in circuit that supplies the key switch. The next place to check for power is at the key switch itself. To hurry this process along you may want to start checking at the back of alternator and go the direction it leads you. If you have more question either email me or post Good Luck, Dave W.
WTW
11-14-2003 07:46:41
Frank, If you can tell me what year model and transmission option your tractor is / has, I can give you step by step instruction on what and where to check to isolate your problem. I do know from what information you have shared that your problem is circuit related. Nothing wrong with your starter, batteries or battery connections. Being your oil and Gen lights do not light your problem may be before your key switch. Let me know what you have for a tractor and I can be more help as the circuitry is different depending on age and options. Good Luck, Dave W.
Dale in IN
11-14-2003 06:08:06
Frank:
If your key switch is located below your steering wheel it is on that panel. You can open that panel by the removal of the 3/8 cap screw at the bottom and all of your switch wiring is in there.
I have had these wires to come loose. Also have had to replace the push button starter switch which is controled from the key switch. But with no idicator lights it sounds like your key switch is not making contact. With a good $4 test light you should be able to find it fairly quick.
John T
11-13-2003 19:12:14
Frank, I havent messed with 4020's much, but can still offer some ideas based on what you say.
If she wont start at the switch, but will if you jump the solenoid, assuming youre jumping the small activation feed wire, its NOT a starter problem or a solenoid problem, BUT a switch or switch wire problem. When you hot wire jump the solenoid and she starts, youre doing the same thing the switch and its feed wires are supposed to do when switched to START.
I suspect the switch is bad, can you get a test lamp on it and find its output terminal which goes down to the solenoids lil activation terminal????? If so, when you turn/push etc the switch to start, that lead should become hot but go off when shes not in the START position.
Of course, the input feed wires and circuit to the switch itself must be good and hot, otherwise it cant supply any of its switched outputs. When you say no oil etc lights come on, that sounds like it may be the wiring to the switch itslef verus any switch contact problems, but I wasnt able to tell from your post if thats actually the case or not???
When she wont start, if youre able to get to and find the switches BATTERY INPUT terminal, see if its hot or not, cuz if not, its not gettign any input power and the problem is in a connection or a wire TO THE SWITCH like maybe from the ammeter etc. The switch cant supply switched output power if its not got any coming into it.
Is there a key or separate switch before and ahead of the START switch?? If so, it has to have power on its input and switch it over to its output for a voltage feed.
Sorry I cant be any more specific, but I have no 4020 diagrams. Regardless, the switch must have voltage on its input and then the terminal down to the solenoid must be hot when in START. If jumping the solenoid always make her crank, then its not a solenoid or starter, but a switch or feed to the switch problem. This also assumes you meant anytime she wont start via the switch she still will if you jump the solenoid!!!!!
Good luck n God Bless
John T
F-I-T
11-13-2003 19:06:12
Frank:
Don't discount a bad key switch or a poor connection on one of the wires. Had to replace one on our '64 4020D once.
If they use any crimp-on terminals (can't remember), they can get loose through years of heat/cool during starting cycles. If so, replace the terminals with good quality ones, and solder them. I like to use heat-shrink tubing on them as well.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
