4240 problem
roger
11-13-2003 18:23:51
our 4240 power shift when round baling works ok for the first few bales but then you push clutch in to twine bale it wont stop, try to put in neutral it will damn near kill it,then the pto stops,the hydralics donnt work,but if you shut it down let set fo a while you can go again, chopping it will do same,when its cold in morning it does not want to move let it run awhile annd you can go thers more thats enough for nw thanks
RJ-AZ
11-14-2003 17:51:44
 Re: 4240 problem in reply to roger, 11-13-2003 18:23:51
Everytime I think I'm a crackerjack tech the Lord humbles me. But I'll take a swing at thisun anyway. This is a problem where time spent on proper diagnosis can save a lot of time and money in the end. Learn how or get someone help you to check the transmission pressures on the C1 & C2 clutch packs.Pull the trans and hydrauic filters and cut them open and check for metal. The screen is behind a big plug down on the left side. Have three clean 5 gal. buckets ready if your oil is good you can reuse it. This is just a start as there are a couple of other thing that can affect the system. Let us know what you find.
RJ-Az
11-14-2003 18:32:12
 Re: Re: 4240 problem in reply to RJ-AZ, 11-14-2003 17:51:44
Gonna be hitting 55 years old pretty quick and I now know that I don't know every thing. But I am pretty good at what I do. Master certified ASE tech in Automotive and Heavy Truck and still learning.
F-I-T
11-14-2003 18:21:28
RJ:
I'm just glad you realized it was a compliment!
F-I-T
John
11-14-2003 20:19:18
 Re: Re: Re: 4240 problem in reply to F-I-T, 11-14-2003 18:21:28
I think that fellow Cris got the term crackerjack mixed up with the term crackerbox. Crackerbox is what my Father used to call just about any car not made in the United States.
WTW
11-14-2003 07:58:55
roger, I agree with david's advice given below. I would be willing to bet also that you have a problem with both your torsinal dampener and your C1 and C2 clutch packs. Sounds like you have either one or both of your clutch pack warped and dragging and when warmed up they will not release. Being you are getting this drag with the clutch pedal down tells me it is mechanical damage / warpage to these elements because oil pressure to them is shut off when the clutch pedal is depressed. A pressure gauge will verify what I am saying. All can be adressed with one split. Good Luck, Dave W.
JDGnut
11-14-2003 09:41:07
 Re: Re: 4240 problem in reply to WTW, 11-14-2003 07:58:55
We have a 4430 split now that had most of the same complaints as you do... The packs were as WTW explained.. plates warped.. and even a few cracked.. Major problem was the heating of the oil.. and the dragging of the packs... Split it.. and dive in... (I would check the pressures first...)
JDGnut
david val
11-14-2003 01:27:45
seems like a combination of clutch pack and torsion damper problem. check pressures in 'tow' position in c1 and c2, see if these are about 180 psi when egaged an 0 when not engaged. use the tm for pressure chart.
david
F-I-T
11-13-2003 19:10:02
Roger:
I had a 4440 way back when, and it acted like that one time. Changed the filters, and I THINK there was a strainer screen to clean, too. I went ahead and replaced the fluid and everything went back normal.
We have a few crackerjack JD Techs who on the board and I'm sure they'll be able to jump in and give you more detailed advice.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
chris
11-13-2003 20:28:26
 Re: Re: 4240 problem in reply to F-I-T, 11-13-2003 19:10:02
Call us CRACKERJACK TECHS, and YOU THINK there is a strainer screen to clean. ENOUGH SAID
F-I-T
11-13-2003 21:57:51
 Re: Re: Re: 4240 problem in reply to chris, 11-13-2003 20:28:26
Chris:
The term "Crackerjack" means "really sharp and good at their job", from the vernacular of the WWII days.
Pity you don't read more, you seem to have missed a compliment.
Frank
chris
11-14-2003 19:20:53
 Re: Re: Re: Re: 4240 problem in reply to F-I-T, 11-13-2003 21:57:51
F-I-T, yes you are right I should read more!! I wasn't in the best of mood last night and I guess your compliment was taken wrong. The only time I've heard the term crackerjack used, it wasn't for anything good. I have helped a few individuals on this board and I interpretted your compliment wrong and I assumed you were saying that a few individuals on this board, like myself would be better off not saying anything at all, then too try and answer their question. Accept my apology and I now have my Websters Dictionary by my side. chris matthies
F-I-T
11-14-2003 19:44:12
 Re: Re: Re: Re: Re: 4240 problem in reply to chris, 11-14-2003 19:20:53
Chris:
Apology accepted.
I really did mean that we are fortunate on this board to have quitea few current and ex-full-time JD techs on the board who always have good advice on the more recent crop of machines. I think even they'll admit that their factory training these days probably only goes back to the 1960 new generation models. It's been up to them, and all of us, to continue to dredge up information on repairing these 43 year old and older, machines. There's an awful lot of information on the pre-1960 models that has to be passed among us all or it will just disappear. That's why I'll always defer to the guys/gals who are up on current models, but I feel I can hang in there pretty well on the old stuff!
We just all need to keep sharing, and be patient with each other.
Frank
And from the dictionary..
11-13-2003 22:02:22
Sorry, I was wrong referencing WWII. Merriam-Webster states the term first saw use in 1895. Says it's "a person or thing of marked excellence".
Geeeee z!!!!! !!!!!
2 entries found for crackerjack.
To select an entry, click on it. crackerjackCracker Jack
Main Entry: crack�er�jack Pronunciation: 'kra-k&r-"jak
Variant(s): also crack�a�jack /-k&-"jak/
Function: noun
Etymology: probably alteration of 3crack + jack (man)
Date: 1895
: a person or thing of marked excellence
- crackerjack adjective
