3020 lift doesn't go to top
Barney
11-13-2003 18:15:21
I just bought a 1970 3020 that has the linkage from the position control lever,L-LD-D missing and the arm that the linkage hooks to on the lift box is broken. I've ordered these two items from Mr. Deere and I hope this will make it possible for the lift to travel full up. I don't think I should attemp to adjust anything until I get these on the tractor. I was wandering if anyone else had ran into anything like this before. The man I bought it from of course doesn't know anything at all about it, since he's a just a resaler, so I don't have any way to get a history on this lift.Any help from an experienced JD man or woman will be greatly appreciated! Thanks in advance; Barney
RJ-AZ
11-14-2003 17:56:55
 Re: 3020 lift doesn't go to top in reply to Barney, 11-13-2003 18:15:21
You may have a broken peice on the load control arm that contacts the rockshaft valve. This is a common problem and it's hard to describe this gizmo. You can remove the rockshaft control fairly easily to do this repair.
Barney
11-15-2003 05:03:46
 Re: Re: 3020 lift doesn't go to top in reply to RJ-AZ, 11-14-2003 17:56:55
Thanks for the info!
david val
11-14-2003 01:37:05
first thing to do, of course, is to intall the missing parts and replace the broken ones, and then see if everything moves freely. however, arms should lift all the way up in d,l and dl positions. if after repair it still dosen't lift properly, a step by step adjustment of the hitch control will be nessessary.
david
Barney
11-15-2003 05:05:36
 Re: Re: 3020 lift doesn't go to top in reply to david val, 11-14-2003 01:37:05
Thanks for the information!
