720 trouble
brian
11-29-2000 17:35:10
I HAVE A 720 GAS THAT I HAVE JUST PUT A NEW MANIFOLD ON AND I WAS WONDERING IF ANYBODY WOULD HAPPEN TO HAVE THE TOURQE SPECS FOR THE MANIFOLD.THIS WOULD BE GREATLY APPRECIATED. PLUS I ALSO CLEANED THE CARB BUT THE TRACTOR WILL ONLY RUN WITH FULL CHOKE WHAT COULD THE PROBLEM BE. I AM GETTING PLENTY OF FUEL TO THE CARBERATUER IT SELF I JUST DONT KNOW WHY THE TRACTOR WONT RUN ANY INFORMATION WILL BE GREATLY APPRECIATED THANKS ALOT BRIAN.
brian
12-01-2000 21:40:54
 Re: 720 trouble in reply to brian, 11-29-2000 17:35:10
got it running today thanks to everybodys comments the jets in the carb were completely clogged and my fuel line was breaking dow and constricting witch limmited the fuel flow. runs good no smoke sounds strong with great oil pressure.
luke
12-01-2000 19:33:24
Check the vent line going from the carb to the gas tank. if its kinked it will limit your flow. i've seen it happen.
WTW
11-30-2000 07:15:36
Brian, Not saying this is your problem or not but being you have replaced the manifolds it very well could be. What can happen is the intake manifold gasket can be installed upside-down still allowing the bolt holes to be aligned but not sealing the manifold to the head which will cause a intake leak and make your carburetor run lean. I have seen this happen on the duplex manifold setup over the years, you might be able to look under the intake manifold with a flashlight and check or start the tractor and spray a little starting fluid under it and listen for engine rpm change. Be careful!! Good Luck Dave Wickman
Gman
11-29-2000 19:26:37
Brian your secondary jets are plugged up,clean that carb. again or send it to Roberts carb. Service in Iowa. later Gman
