Additional WF Info
MIKE HANLEY
11-13-2003 16:52:00
Someday I'll get all togther and get it all done it one shot instead of having to PS and PPS Remember CALUMBO on TV. Well I guess that was the kind of cop I was. Kept comming back throught the whole show. Any way,, When I sent WjW the pixs of the wide front end I remembered some imporant info on the thrust washers in the wide front that I should have posted in my answer to him below. In each knee at the bottom are two thrush washers that are held in place with small pins. One pin is pressed into the casting of the spindel and one pin is pressed into the lower part of the knee. These pins keep the trush washers from turning so that when you turn the tractor the rubbing takes place between the washers. If the pins are broken the washers will turn causing wear on the casting and the lower part of the knee. I have only taken one WF apart that did not have broken pins and show wear on the casting and in the knee. You can't drill the pin out and you can't get a drill in straight to drill a straight hole on the spindel. You can drill in an over size hole at an angle and then put in the pin with JB WELD. What I do is jack up the tractor and turn the whole knee upside. Then with the turning surface coated with never seaz coat the pin and the other side of the washer with JB WELD. Then do the same with the washer on the spindal and put the spindel into the knee using the weight of the spindel to hold the parts while drying. When dry the next day pull out the spindel and check that the washers are solid. Then turn the knee back to it's proper position and finish reassembleing. This and having the 6 bushings in good shape is just as inportant as daily greasing.
ET
11-14-2003 07:02:39
 Re: Additional WF Info in reply to MIKE HANLEY, 11-13-2003 16:52:00
Mike,
Here is a way to get out those thrust washer stablizer pins. The pin is a spring roll pin so its hollow. Find a straight punch that will just fit inside the roll pin that can be tapped to the bottom of the hole. Now the crazy part, go out and get some dirt wet clay works well. Put the dirt in the center of the roll pin and push it down with the punch. Keep packing it in till the hole is full. Now put the punch against the dirt in the center of the roll pin and hit it with a hammer. You may need to add more dirt, as the dirt in punched in the roll pin is forced out. This sounds crazy but it usually works.
MIKE HAN LEY
11-14-2003 12:09:34
 Re: Re: Additional WF Info in reply to ET, 11-14-2003 07:02:39
If there is an expantiom pin in there it's something that someone put there after it left the factory. The pins (part # F1743R) are solid pins. We have enought parts in our parts pile to put together a complete wide front. Last month I got some new pins and also new thrush washers to finally start put all the parts together. That will give us three wide front ends. John Deere subed over the thrush washers and a first glance they look like the old ones, there is an extra hole in the new ones. Also the bushings are differant from the old bushings. You have to be carefull to line up the hole in the bushing with the grease zurk.
ET
11-14-2003 12:18:06
 Re: Re: Re: Additional WF Info in reply to MIKE HAN LEY, 11-14-2003 12:09:34
Mike it was 4020 and 3020 axels I used this on they must use a roll pin instead of a solid pin.
