Date matching hay equipment for my JD60
Eric
10-14-2003 05:39:10
I have a 1952 JD60 and 10 acres of hay to tend next summer. I have rebuilt a #5 mower and purchased a 555H 3 btm plow and an un-identified 8' JD disc. I need to add yet a rake and baler and would like to match as close to the time period I am already in. I have been told a 14T Baler might be a good choice but also need a crimper/crusher and rake. Can anyone give me some direction.
Dave H
10-14-2003 10:15:23
 Re: Date matching hay equipment for my JD60 in reply to Eric, 10-14-2003 05:39:10
I use a #5 (two in fact) for cutting my hay with a Farmall SMTA. I do not really understand the need to date match equipment, but I guess you know what you want. When you are out in the field you may start wishing you had a little newer machinery so you could enjoy your tractor more and fix equipment less. The #5 mowers are great and should run without a hitch. Just don't forget to grease them on schedule, especially the flywheel side of the pitman. As to the crimper, you don't need it. Pick a time when the weather is good and let the hay dry an extra day. We have great luck doing this.
New Idea had one in 52
10-14-2003 09:22:58
went behind the mower and did the last round cut while you mowed the next.
F-I-T
10-14-2003 09:40:13
 Re: Re: Date matching hay equipment for my JD60 in reply to New Idea had one in 52, 10-14-2003 09:22:58
I remember a lot of mowers got traded in because they lacked the pto that came out of the gearbox to drive the crimper. We bought a NI 7' pull-type that was just like new that had been traded in for that reason.
Frank
MIKE HANLEY
10-14-2003 07:56:06
The post below is correct. Crimpers did not come out till the #8 mower was made in about 1958. The tender or fluffer (JD #2) also did not come out that then also about 58 or 59. You are correct with the #5 mower and the 14T baler just makes your imeperiod as they came out in 1956. As to a rake the only rake in the line at that time was the 594LW, which looks like an old horse drawen rake, but on low rubber. Hence the LW. They at that time still offered the 594 with high steel wheels. As to getting it to dry, in those days it was just waiting an extra day.
MIKE HANLEY
10-14-2003 08:13:22
 Re: Re: Date matching hay equipment for my JD60 in reply to MIKE HANLEY, 10-14-2003 07:56:06
Sorry about the grammer in the above post. The phone rang and I had to go off line and was in too much of a hurry to do it right. Wagons at that time would be the 943 economy, the 953 standard and the heavy duty 963. The elvator at that time did not have a number.
CJDave
10-14-2003 06:14:51
I could be wrong about this, but I'm pretty sure that conditioners had not yet come onto the market when your 60 was a current model tractor. When I was a kid we lived in CA and I recall hearing about something called a "tedder" but never knew exactly what it was. My impression was that it was a sort of hay conditioner that they used in the faraway midwest, but even that would have been in the late fifties.
