JD B radiator
David
11-28-2000 06:39:23
I'm trying to remove the radiator on my unstyled B. I have all the bolts removed but can't break the top tank loose. I assume corrosion is holding the tank down. I've tried light wedging with a thin scraper blade but I'm scared of breaking the flange. Does anyone have any suggestions or experience with this problem?
Dick Cumiskey
11-28-2000 18:06:17
 Re: JD B radiator in reply to David, 11-28-2000 06:39:23
Sounds to me as if someone used a permanent (hardening) type gasket sealer to stop leaks. You might try soaking the flange in MEK, available at many paint stores or places like Home Depot.
