4430 question
Patrick Schaefe
11-13-2003 15:02:03
I have a 4430 quad range that does not back up in C range. It works fine in the rest of the gears. When you have it shifted in to reverse C it doesnt make any noise or movement. Do you have to remove the transmission and or the cab?
chris
11-13-2003 20:15:07
 Re: 4430 question in reply to Patrick Schaefers, 11-13-2003 15:02:03
Pat, see if adjusting the shift rails help, your cab mounts might be broke or the rubber is getting flattened out. Also remove the floor mat then the floor panel, then you can remove the top cover and look in the tranny. If it needs to be split, it separates at the clutch/trans housings bolt together(or right in front of the top cover you removed, and not a double split. The trans/rearend rolls out from under the cab. Splitting and the rockshaft housing needs to be removed in order to service syncro's. chris
RJ-AZ
11-13-2003 17:39:26
Gotta pull the cab to at least pull the top cover plate to see whats going on. It's been too many years since I've been into one of these but I think you have to split it TWICE and pull the rockshaft housing to get to everything. Check the sump screen for metel debris and cut open the trans filter also. Rotsa Ruck on this one Patrick.
