JD A head part number
Drew s/w WI
11-25-2000 15:30:31
Hello: My friend has a 1950A. The head part number is A4227R. He had the time to check the oiling going on for the rocker arms and noticed that one is not getting any oil. He says that the head keeps the oil from reaching that rocker arm. Could someone give me the right part number? I hope I explained this right. Thanks in advance. Drew s/w WI.
Mike Aylward
11-26-2000 06:17:20
 Re: JD A head part number in reply to Drew s/w WI, 11-25-2000 15:30:31
Drew, Rollo is right about the part numbers and the casting numbers. One thing you might check is the casting on the lower, center stud where the oil line fastens. Sometimes it gets warped or cracked, or someone puts the lead washer under it instead of on top, and it can seep. May not be the trouble, but something to check. It may also be possible that your oil line above the rockers is plugged. Hope this helps. Mike
Rollo
11-26-2000 06:10:46
My JD parts book says the part number for a JD "A", from serial no. 584000 on (about 1946 or 1947) is AA 4949 R. This is the part no. which includes valve guides and studs. It also mentions just the head number alone being A3367R or A4226R.
