4840
tim
10-14-2003 05:29:26
I have 4840 with p-style injecter pump I would like to turn pump up a little bit to give a little more power can the pump be turned up without taking pump off tractor and taking it to a shop??? what are the procedures for turning up pump???
G-MAN
10-14-2003 07:33:49
 Re: 4840 in reply to tim, 10-14-2003 05:29:26
I've turned up several 4640s and 4840s for customers, and when tweaking them after getting pump work done, and I wouldn't suggest turning that screw more than 1/2 turn. I've done a bunch of them while on the dyno, and although they're all a little bit different, a 1/4 turn should give you 10-15 horsepower or so. A solid half-turn should be good for 25-30. It's best to do it while on a dyno, so you know where you're setting it. 4840s will make all kinds of horsepower, the only problem is that in high-load hard pulling, the head gaskets don't like it much. They've improved it by changing the gaskets and bolt-torque sequences, but we still see a lot of 4640s and 4840s leaking oil out of the head gaskets. The late 50-series, 55-series and 60-series engines are much better about keeping their head gaskets in when turned up. If you plan on working it hard, I wouldn't turn that 4840 up to more than about 225 horsepower. They seem to live pretty good at that level. My two cents.
Stuart Martin
10-14-2003 07:19:31
Yes you can turn the pump up with out taking it off the tractor. You have to take the square cover on the end of the pump off. I think they are a 10mm or SAE equivilant. Then you will see a screw type stud and a jam nut on it loosen the jam nut up and turn the screw. I would only turn it 1 turn and not any more. If you turn it in to far you will retard the pump and actually not get as much power. I have 2 4455 that I take to the tractor pulls. I turn them up all of the way and then turn up the rpms. When they are getting a pile of fuel they need the rpms to burn it all.
I take them from 2400 to 3500. I dynoed them at 400 hp. They turn 165 hp stock. Becarful if you have a power shift trans if ur really gonna turn the screws to her. What do u need the extra power for, just wondering, good luck
tim
10-14-2003 08:45:33
 Re: Re: 4840 in reply to Stuart Martin, 10-14-2003 07:19:31
Iam only pulling a 9 shank chisel plow right now and wanted a little more power, ps do i turn screw
in or out to give more fuel?
Rob
10-14-2003 11:03:30
 Re: Re: Re: 4840 in reply to tim, 10-14-2003 08:45:33
A 4840 should pull a 9 shank chisel plow just fine without messing with the fuel screw. I have a 4230 with an M&W turbo (about 120HP)that will roll across a field with a 9 shank chisel plow. I have also pulled my 5 shank parabolic ripper with it as well.
Are your tires worn out? I just replaced the old tires on my 4230 with BFG radials on my 4230, and I was amazed at how much better it pulled.
tim
10-14-2003 12:07:27
 Re: Re: Re: Re: 4840 in reply to Rob, 10-14-2003 11:03:30
it pulls the 9 shanks well and i pull a 26ft field cultivater with it and it does well, but my griund is all heavy clay and it takes alot of tractor to pull anything around here, we also have a 4440 and it is not far behind the 4840 for power so i felt that the 4840 could use some more fuel to bump up the horses some. I have know idea what is at now for horses.
Rob
10-14-2003 12:41:48
 Re: Re: Re: Re: Re: 4840 in reply to tim, 10-14-2003 12:07:27
Yeah you need more horses in that heavy clay. We are in the VA coastal plain and have loamy soils. I have a 4440 too and mine puts out 145 on the dyno. Dad bought it new in 79, and I know the fuel screw has never been touched.
I have run my neighbor's 4840 and it definately has a LOT more power than my 4440. He pulls a 30' foot disk with a 30' cultipacker behind it and you hardly know it is back there.
G-MAN
10-14-2003 13:43:58
 Re: Re: Re: Re: Re: Re: 4840 in reply to Rob, 10-14-2003 12:41:48
145 horsepower is pretty much right on for a stock 4440. Most stock 4840s will run in the 190-200 range. For one that's been "tweaked", 225-230 is about average. However, in some conditions and applications, it is possible for a 4440 to pull with a 4840, because their respective horsepower-to-weight ratios are very similar. 4840s have quite bit more power, but they also carry around quite a bit more weight. I never underestimate the capability and durability of the 4440, ever since I saw a "stock" one turn 260 horsepower. The guy didn't pull it or anything, just farmed with it. I think he got into a situation like this - someone showed him how to turn it up, and he got carried away. I also dynoed a 4430 once that made 245 horsepower. I had to turn the screw out three turns to get it back down to 145. I guess there's a reason they tried to hide those screws, lol.
Rob
10-15-2003 07:06:53
 Re: Re: Re: Re: Re: Re: Re: 4840 in reply to G-MAN, 10-14-2003 13:43:58
My 4230 had to have a new engine put in it at 2K hours because the farmer that owned it let his son pull with it. He installed the M&W Turbo and turned the fuel screw way up and blew the engine up at a tractor pull. I got a heck of a deal on it at an auction several counties away back in 1988. All I knew was that it was a really nice late model 4230 with a cab, and 500 hours on a brand new engine, and it was going for a give away price. I think the reason it went so cheap was because all of the local farmers knew about it and would not touch it with a ten foot pole. The guy's other tractors brought a heck of a lot more. I paid 13K for this tractor and an older 4230 right next to it with more hours brought 19K. The auctioneer and the owner said that the engine was defective. The mechanic at the dealership that did the work told a different story, but he also told me that the tractor was in excellent shape becsue the old man never let the boy pull it again after the engine had to be replaced. Never had a minute's worth of trouble with it in the years that I have owned it, and it was the best deal I have ever gotten at a farm auction.
grnwrnchr
10-14-2003 10:59:55
Hi,
Turning it "in" 1/4 to 1/2 turn should give you right at 10 hp. As with the other comments, I wouldn't go the one turn or over, esp without a dyno to check it. Watch your temp gauge.
G-MAN
10-14-2003 10:57:34
You turn the screw in to increase fuel delivery. Like I said in my post, I don't think I'd go a full turn right away, but I guess that's your call. That is a bunch more fuel you'll be putting in. It's pretty easy to get carried away once you know how to do it, and it WILL have detrimental effects on your tractor and engine, particularly if you're pulling it hard on a ripper. If you turn it up some, and notice that you're getting a lot of black smoke when pulling, you may as well turn it back down some. All that black smoke is is wasted fuel, and if it's smoking like that, it's burning all the fuel it can, and putting the rest out the pipe. That's also not good on your engine, as you can get enough fuel in the cylinders to wash down the oil on the liners, and score a piston. You can also end up with some excessive exhaust temps and boost pressures when cranking one up too far, Also, when you remove that cover, you'll lose some engine oil out of the governor housing. It won't hurt anything, but it will make a mess.
tim
10-14-2003 12:11:36
 Re: Re: Re: Re: 4840 in reply to G-MAN, 10-14-2003 10:57:34
do i remove that whole cover on the injecter pump to get to that fuel screw, and will that cover come off without removing the oil filter assembly
G-MAN
10-14-2003 13:39:30
 Re: Re: Re: Re: Re: 4840 in reply to tim, 10-14-2003 12:11:36
I've done them both ways. On some engine/pump combinations, you have quite a bit of room to get to that cover, and on others, it's a little tighter. Take out the two top screws and the outside bottom one, and loosen the other one and leave it in place so that the cover will pivot out of the way. It is sealed by an o-ring in the governor housing. Even without replacing that seal, I've never seen one leak after being opened. Just don't get carried away when reinstalling the screws, as they're screwed into a fairly thin aluminum housing. I seem to recall that the actual locknut is 12mm, and the fuel screw is slotted for screwdriver, although it should turn easily with your fingers or by lightly using needle-nose pliers, so as not to screw up the threads. Just make sure to screw it in and not out. The jam nut doesn't need to be real tight, either. Just snug it up a little. It's also smart to do it with the engine cold, as that will minimize the amount of oil you lose, and keep you from burning your hands on the filter housing.
