B carb
Tim M
11-24-2000 06:28:02
I'm rebuilding the carb on my 42 B and I am going to drill out the idle passages and I was wondering if you have to take out the nozzle to do this? I ordered the bits from Robert's Carb repair and they should be coming. Thanks, Tim
John T
11-24-2000 13:11:12
 Re: B carb in reply to Tim M, 11-24-2000 06:28:02
Tim, clooney is right you dont have to remove the nozzle to drill those 3 idle passages, but if the nozzle is in so tight it doesnt fall out easily, it will not be right until you remove, wire brush, clean it, then clean the bore it fits into until the nozzle/bore tolerance is right. On my DLTX10 I used a 10/24 DRILL AND TAP to pull the nozzle out. John T
clooney
11-24-2000 07:16:53
third party image
Tim, you don't have to remove the nozzle but I would suggest you do as there are little holes in the side that should be cleaned. Just thread a sheetmetal screw or tap the bottom for a small screw then clamp a pair of vice grips on the screw then tap downward on the grips with a hammer.
Tim M
11-24-2000 10:10:09
 Re: Re: B carb in reply to clooney, 11-24-2000 07:16:53
Thanks for the help. The parts just came in the mail today. Thanks again, Tim
