70 gas flywheel
Don H
11-23-2000 18:09:34
My 70 gas developed a knock. My local JD two-cylinder mechanic says the flywheel is loose on the crank. How is best and most reasonable (money-wise) way to fix this problem? Is the Tapr-lok thing the best way to go? Seems expensive especially since you give them your old flywheel in exchange.What kind of bucks are we talking? I am hearing about $600.Any help for this amateur would be appreciated.
Gman
11-24-2000 06:21:55
 Re: 70 gas flywheel in reply to Don H, 11-23-2000 18:09:34
Don I have had good luck with Locktite on flywheel splines,also try some new fine threaded bolts. Don't forget to set flywheel end play when you put flywheel back on.A twenty-five dollars bottle of locktite sure would beat the price of taper-lock. If you ever need to remove flywheel for some reason and you use locktite,you might have to use a torch to get the locktite to releasee.Later Gmaan
Don H
11-29-2000 06:56:15
 Re: Re: 70 gas flywheel in reply to Gman, 11-24-2000 06:21:55
Hey guys, that fine threaded bolt idea sounds good but where in the heck do you find them? No one has a 3/4 by 5" with a square head!
clooney
11-23-2000 20:06:14
Don, you might want to try BigJ's sugestion only remove the coarse pitch bolts & install new fine pitch bolts & really tighten them. If it isn't torn up too bad you might get the flywheel tight enough.
BigJ
11-23-2000 19:26:09
Hey Don,if it just developed see if it can be tightened more.Do not be afraid to put some good pressure on the bolts.I believe I would try that before I spent 695.00 for a taperlock flywheel,although you may very well have to do that.Let us know what you find,Jack(TN).
