37 AR rims
Tony
11-13-2003 11:59:38
I am in the process of welding up some holes in a 37 AR rims and noticed that there is two hole for what appears to be for the valve stems. Can anyone say why the second hole is there, and will closing up the extra will bring the value down? Thanks
joe
11-14-2003 13:41:23
 Re: 37 AR rims in reply to Tony, 11-13-2003 11:59:38
You might search archives, seems to me there was something posted a couple of weeks ago about the two valve stem holes.
Dave in Ohio
11-13-2003 15:15:04
I just picked up a set of flat spoke ten spline wheels off an unstyled B. They also have two holes and although the tires are shot they do have a tube in them that comes through the inner hole, so it was used sometimes. I am also interested to know why and if it took a special tube. I wouldn't weld them up until we find out.
Daryl
11-13-2003 13:40:15
Are the rims mounted on a cast center? If so does it have two square pieces of steel riveted to the rim? If these are gone, it would leave two holes. The square pieces kept the rim from spinning.
Tony
11-14-2003 03:03:02
 Re: Re: 37 AR rims in reply to Daryl, 11-13-2003 13:40:15
Yes you are correct, they do hhave that square piece on them. I have tried all tricks to get them apart and no luck. So I just sand blasted them as one heavy piece. There was a little rubber boot, but now I can not find it. After 30 years of calcuim leaking on them, the rims are in pretty good shape. Thought of putting the old valve stem in with JB Weld on the inside hole and the tube stem on the outside hole just to fill in to help protect the tube.
