JOHN DEERE 2010
JB
11-21-2000 18:23:03
I have a John Deere 2010, with narrow front end. The motor is locked up. I am getting ready to tear it down. How hard would it be to replace the old gas motor with a diesel? I have used a MF diesel for a long time now and hate to use a gas tractor again. Where could I find a diesel 2010 motor? Should I just rebuild the gas engine? The tractor set out for a while, so there is probably more problems. I got my work cut out for me. It use to be a powerhouse for it's size. Any info or suggestions will be appreciated. Thanks.
Stranger
11-21-2000 20:49:05
 Re: JOHN DEERE 2010 in reply to JB, 11-21-2000 18:23:03
Stick with the 2010 gasoline engine. Converting a 2010 gas to a 2010 diesel would take a 2010 diesel parts tractor, and since the 2010 diesel wasn't much good when they were new..... ..... well, you get the picture. The simple and cheap fix to this one is a 145 engine from a 45 combine, bolts right in with no trouble, especially if you use the manifolds, governor, carb, etc from your existing 2010 engine. 45 combines from 1957 through 1966 used this engine, so they are not hard to find in most areas. I like diesels myself, but this fix is the most cost effective in both the short and long run.
JB
11-22-2000 01:51:35
 Re: Re: JOHN DEERE 2010 in reply to Stranger, 11-21-2000 20:49:05
Thanks!
