720d std. fuel for clooney FIT anybody
Tracy Redd
11-13-2003 10:21:48
I almost finish working late 720 D and putting back together next week.
This tractor ran last summer before take apart I disconnect all fuel lines snd takes off fuel tank but not the fuel filter yet. It gonna be hard to start to pump the fuel to get fuel injector.
How do i prime it or pumping the fuel to get injector? Do i have keep cranking to pump the fuel? How do you bleeding the fuel lines?
I am trying to get it start with out problem. I do have manual but it'll easier from your answers
Thanks
Tracy
Clooney
11-13-2003 14:51:46
 Re: 720d std. fuel for clooney FIT anybody in reply to Tracy Redd, 11-13-2003 10:21:48
Tracy, Frank posted a good bleeding discription below..
~If you have been cranking that tractor long enough to pump air into the injector lines you will probably have to pull the rocker cover & also bleed the injector lines at the injectors.. You might get away with a gravity bleed of the injector lines or you might have to bleed them while cranking [after the filters & lines are bled].. Once air gets into the injector lines [& injectors] it would rather compress than pop the injectors open..
[email protected]
Hoppy
11-13-2003 14:17:43
My first diesel overhaul was an 830 el, when I thought I was ready for srart up I adjusted the intake valves tight and blocked the compression release down, cracked the fuel lines at the injectors, and turned over the flywheel by hand until I had a steady stream of fuel at the injectors. When I felt it was without bubbles I tightened the fuel lines, released the compression release, readjusted the intakes, pulled it into the street, had my wife pull me. It started in 5 feet, sounded great. After warm up I readjusted the valves and it started with the electric starter and compression release. After having that big of an engine down and it being my first Diesel I can't remember a better sound.
F-I-T
11-13-2003 14:21:53
 Re: Re: 720d std. fuel for clooney FIT anybody in reply to Hoppy, 11-13-2003 14:17:43
Hoppy:
If I asked my wife to pull my '70', she'd be pretty irked if I didn't let her use another tractor!
Sorry..... :)
F-I-T
11-13-2003 14:15:22
third party image
Tracy:
If you have a decent amount of fuel in the tank (4 or 5 gallons), you should be able to bleed that system out by gravity. Now I'm speaking from the '70'D perspective, so it could be different on your 720, but possible only at the last step.
First, make sure you have the lever on the sediment bowl open.
Next, remove the bleed screw (#1) on the left-hand side of the fuel filter assembly (left is the aircleaner side), and let the fuel run until it is bubble free. Replace the screw while the fuel is running and snug it up. Next you do the same thing with the screw (#2) on the right hand side (remove, fuel runs no bubbles, replace snugly).
Last you go to the governor linkage housing on hte left hand side of the engine block, about in line with where the sediment bowl would be, and remove just the screw (#3) and let the fuel run until free of bubbles.
That should do it. It should start with minimal cranking.
Let me know if you need anything else.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
