John T
11-22-2000 06:19:29
Re: Re: Re: JD A Charging Circuit in reply to Tom, 11-21-2000 16:03:12
Tom, Yes, all I said above about the A and how to troubleshoot it applies to your 70. Just re read it and do the same. That Bat terminal on the VR has to have battery voltage on it (a wire to and through any series ammeter then to the battery), otherwise, even if the gen is working, it isnt getting to the battery to charge it. Then, if the VR cutout relay is working properly, that isnt internally conected over to the Gen/Arm terminal until the generator voltage rises to charge the battery. Take a jumper, and with the tractor running, ground the Field terminal and see if she charges then. If so, its a faulty VR. Then with the tractor running, if the wire going to the VR Bat terminal is hooked over to the Arm or Gen terminal and she charges, again, its a faulty VR (cutout relay not closing). If neither of those makes her gen and the wiring is all intact, its likely a bad generator usually a brush or brush hold down spring problem. Also, you can remove the generator belt and with the field grounded and voltage appled to the Arm terminal on the generator, if working she will motor (run) if its good. Let me know what your troubleshooting tells you and you can worry about where to hook your light circuit (L) later. Ol John T Engineer in Indiana
