Block cylinder sleeves
Cordell
11-19-2000 15:06:12
I am wanting to bore out my 620 LP block and sleeve the bore to accept standard piston. Any information on where I can locate a supplier. A 5 1/2 slightly undersize inside diam. cast iron pipe that has 1/8" thick walls will work.
Gman
11-20-2000 17:37:51
 Re: Block cylinder sleeves in reply to Cordell, 11-19-2000 15:06:12
Cordell I had my 70 sleeved back to Std. Cornett Machine Shop in Somerset Ky charged me two hundred dollars a hole and furnished the sleeves. If you are looking for sleeves call Darton Sleeves 1-800-713-2786 or try www.darton-international.com Later Gman
will
11-20-2000 16:30:35
I wanted to get my A sleeved and two machine shops quoted me $900.00 for both.
clooney
11-19-2000 15:20:13
Cordell, talk to the machine shop that you are going to have do the job, I don't know what part of the country (or even if out of the U.S.A.) you are in but where I'm from my local machine shop, or at least the one I use has access to different sized sleeves to install.
burnsOmatic
11-19-2000 18:09:28
 Re: Re: Block cylinder sleeves in reply to clooney, 11-19-2000 15:20:13
Some sleeves are difficult to come by. One of the major suppliers for sleeves located in Louisana is not longer in business. Just hope the bore and the length of the sleeve is fairly common (which it should be). By the way they are not cheap.
