JD 2510 and 3020
Tony
11-18-2000 14:27:50
How can you tell the difference between a 2510 and 3020?
Bozo
11-22-2000 14:13:00
 Re: JD 2510 and 3020 in reply to Tony, 11-18-2000 14:27:50
Tony, the 2510 will have the numbers "2510" on the side panel under the dash and the 3020 will have the numbers "3020". Ha Ha Ha Ha Ha Ha Ha!!!!! !
I couldn't resist, sorry.
Mike Aylward
11-19-2000 06:03:14
Tony, from a distance there are several ways to tell the difference. A 2510 will have a thin round muffler as opposed to a larger round one on a 3020 of the same vintage. The 2510 will have a protruding right hand side shield (where the "2510" decal is) and the 3020 will be flat. An easy way to tell the difference from the front of the tractor is to look at the relationship of the front grille to the hood seam. On a 3020 they line up. On a 2510 the grille is higher than the hood seam. Hope this helps. Mike
McC
11-19-2000 00:32:23
Check the oil filter. 2510 has a spin on oil filter. Tha 3020 has a cartridge type in the oilpan.
ROBERT
11-18-2000 20:25:59
Thay both were made by JD
3020 is about 70 hp
2510 is about 50 hp ROBERT
tommy
11-18-2000 17:53:48
3020 has a taller engine block,engine head is shaped like a 4020 although it has 2 cylinders less than a 4020.3020 has starter on left side.The front grille is about an inch taller on a 3020 as opposed to a 2510/2520
zane
11-18-2000 17:07:04
The 3020 is slightly taller. The fluted area of the front grill is deeper.
Tony
11-18-2000 18:17:05
 Re: Re: JD 2510 and 3020 in reply to zane, 11-18-2000 17:07:04
Thanks guys for the pointers. I failed to say these were gasoline engines, does everything still apply?
