520 Hydraulic leak
Gary Mckenzie
11-13-2003 06:10:38
I'm working on a friend's 520, it's leaking hydraulic fluid from somewhere behind the top link bracket. There appears to be a spring and possibly a plunger of some type (draft control maybe?) that goes into the case. Is there a seal here? If so, how much of trouble is this to repair. I have an I&T manual, but this assembly doesn't seem to be in it... Thanks!
Clooney
11-13-2003 06:43:56
 Re: 520 Hydraulic leak in reply to Gary Mckenzie, 11-13-2003 06:10:38
Gary, yes, there is a seal in there on the load control yoke shaft..
~It is a fairly intense job the first time you do it but by the second or third time it isn't that difficult..
~I haven't looked in a while but I'm pretty sure that procedure is in the I & T manual.. I believe it will even have pictures & procedures for building a tool to hold the reaction piston in the load control dash pot while you take it apart.. The load control shaft has to come out of the rear housing to replace that seal..
~I am posting from a remote location & don't have access to my data files or manuals but if you need a picture of the parts breakdown for that shaft & housing, or clarification on any of the I & T manual procedures just post back or E-Mail...
[email protected]
Gary Mckenzie
11-13-2003 16:02:14
 Re: Re: 520 Hydraulic leak in reply to Clooney , 11-13-2003 06:43:56
Clooney, Thanks for the info, I was hoping there was an easier fix than removing the rockshaft cover and housing, but I guess it won't be to bad. I'm used to working on much larger stuff so maybe it won't be to bad. My manual shows everything but the plunger, but I should be able to figure it out. Thanks!
