Desperate need of model A radiator flange for filler cap
Luke
11-14-2000 08:45:18
Hello, I am currently fixing a 1941 "long hood" A that takes 4 1/2 inch radiator cap. I need to find a filler flange for it (what the cap screws on to), radiator shroud, all-fuel lines to starter tank, and linkage from all-fuel lever to tank. If anyone has these parts new or used please email me ASAP. (Already went to oldjd4u website and they amazingly didn't have all of these parts.) Thanks, Luke
Nate
11-17-2000 07:03:27
 Re: Desperate need of model A radiator flange for filler cap in reply to Luke , 11-14-2000 08:45:18
The fuel lines are available thru Deere. But the radiator flange part number A1607R isn't. I just sent for one today. Minn-Kota repair out of MN. for $32.50. Check the web site at www.minnkotarepair.com
Burl Ewell
11-14-2000 18:14:39
Brian is right on the money. The first place to check is your local JD Dealer. I got a radiator flange for my 47 A from them, and they do have a lot of the other parts.
brian waller
11-14-2000 17:41:18
DEAR LUKE I AM ALSO RESTORING AN A JOHN DEERE BUT MINES A 42 MODEL. I HAVE HAD TO TRACK SOME OF THESE PARTS DOWN MYSELF. YOU PROBABLY WONT BELIEVE THIS BUT YOU CAN STILL GET THE RADIATOR FAN SHROUD NEW FROM JOHN DEERE I BOUGHT ONE FOR MIN THINK IT WAS AROUND 70 DOLLARS OR SO.NOT MANY PEOPLE KNOW THIS. GET A PARTS BOOK AND GET THE DEALER TO LOOK PART NUMBERS UP FOR YOU IT PAYS OFF I HAVE FOUND MANY NEW OLD STOCK PARTS THIS WAY.AS FOR THE GAS LINE IT TOOK ME A LONG TIME TO FIND MIN ALL I CAN SAY IS KEEP LOOKING AND YOU SHOULD BE ABLE TO FID THE SELECTOR ROD FAIRLY EASY I KNOW SOME ONE THAT MIGHT HAVE ONE ILL KEEP YOU POSTED.GOOD LUCK AND HOPE THIS HELPS OUT BRIAN P.S ALSO YOU CAN FIND REPRODUCTION FILLER NECKS THROUGH STEPHEN EQUIPMENT IN FRANKTOW COLRODO.
