Carb on 39 B
Mark R
11-12-2000 05:57:43
the carb on my 39 b wont hold fuel. have a line and clear hose and fill to top it will hold fuel for a while when cranking then just runs out.all gose in LH cylinder.carb has been cleaned soked all ports are open new needle and seat gaskets. still runs right through HELP
BMAN
11-12-2000 06:35:32
 Re: carb on 39 B in reply to Mark R, 11-12-2000 05:57:43
The float may need to be replaced or the needle and seat. Also there could be a small piece of rust in the needle and seat. I always take the screen out just above the seat and check for rust underneath. Shake the float to see if it has gas inside.I rebuild carburetors if you need any more help.
