How much pressure in hydraulic return lines?
Charles
11-11-2000 17:35:24
I can't find a steel line to replace the rusty Powr Trol return line on my 70D, so I was thinking of cutting out the rusted place and using rubber hose with clamps. Has anyone tried this? What is the maximum pressure in the return side? If it's always less than about 50 psi this would work but if there are "spikes" to 1200 psi (the max. high side pressure) then instant oily mess...
STMTS
11-12-2000 07:04:07
 Re: How much pressure in hydraulic return lines? in reply to Charles, 11-11-2000 17:35:24
Take your old rusty line to someone who makes hydraulic hoses and they can either replace the whole line or cut out the bad spot and weld on fittings and put in a section of high pressure hose.We make them all the time.
jim cook
11-11-2000 19:46:22
Charles, I don't know why you would get instant oily mess. I replaced a cracked line on a 2440 with an 18" section of hydraulic hose and a 2440 has considerably more pressure than a 70. Think about it, these same hoses handle full rated pump pressure in a hyd cylinder. You might need special fittings though.
