Busted block repaired with fiberglass
ZANE
11-10-2000 20:05:34
third party image
This is the block out of an LA that a friend of mine repaired with fiber glass. Tell me you can't fix most blocks!!!
doc
11-11-2000 11:17:18
 Re: Busted block repaired with fiberglass in reply to ZANE, 11-10-2000 20:05:34
No disrespect intended, but lets see it after 10 hours, will it hold against the heat, vibration and stress?
If it works... heck... it's another way to keep these old machines popping!
Doc
G Taylor maybe
11-11-2000 06:08:25
Presurized,load bearing etc areas are best "V" ground,preheated and nickel rod welded. They are those occasions when "wonder glues" such as JB weld works and works well but each repair method has it's place.
