Gas tank on '51 B
Kris
11-05-2000 20:35:16
I just got my first JD home last week and removed sediment bowl and it was packed with rust chips. Took a magnet and tried to run it through the tank as best I could and got a lot of little chips out. Since I am still a poor college student would it work if I just put the garden hose in the tank and try and get the rust out that way with the sediment bowl still removed? Total restoration is not in the picture yet so I would rather not buy a new tank. I appreciate all input from all you JD wizards.
JimA TX
11-06-2000 08:47:54
 Re: Gas tank on '51 B in reply to Kris, 11-05-2000 20:35:16
I had the same problem on my 50 B. Ended taking the gas tank off the tractor, dropping some large steel balls in it, shaking the balls around the tank and then removing them. You would be surprised at the rust that came out of the tank!
I used steel ball bearings that were small enough to drop out of the sediment bowl fitting.
Good luck on your restoration when you get around to it.
JimA TX
Kris
11-06-2000 10:14:01
 Re: Re: Gas tank on '51 B in reply to JimA TX, 11-06-2000 08:47:54
Thanks guys for the input. My grandfather gave me pretty much the same advice, but I wanted to make sure. I have heard a few horror stories of people ruining their gas tanks by using too powerful of a hose. Once again thanks very much!!
Ray
11-06-2000 05:48:36
Had the same problem on a Farmall we acquired recently. Finally resorted to emptying tank, removing it and power washing it inside until the water came out clean. When I reinstalled the sediment bowl assembly, I stuck a small piece of tubing, (piece of old car radio antenna,) in the inlet to the assembly, so that the actual fuel intake is half an inch or so above the bottom of the tank. This reduces the dirt pickup.
