John Deere 830
Michael
11-04-2000 19:13:31
A couple of months ago I posted a message on rebuilding my 830 with a stuck engine. Want to say thanks for all the good advice. Thanks clooney. I have replaced the bad piston, both sets of rings valves, and honed the walls. Replaced all gaskets and completly reassembled motor. I believe I have motor timed correctly also. When trying to start, diesel appears to almost start, alot of smoke coming out the stack, but motor will not start. I am fairly positive motor is getting gas and I have had the injectors professionally rebuilt. Anybody have any ideas I must be very close. Would like to drive before the snow falls
Duane(pa)
11-05-2000 14:04:49
 Re: John Deere 830 in reply to Michael, 11-04-2000 19:13:31
Turn thr big engine flywheel by hand and see if you hear any compression leaks. really you should't be able to turn it on full compression. My injecters were cocked when I went to start mine and she really smoked. Check that the injector clamps are free on the stud and all the tightness is being applied to the injector pushing it tight to the head.
G Taylor
11-04-2000 20:38:39
Could you list the starting steps you are using in sequence? What cranking compression does the diesel have and what RPM can the pup/pony achieve while cranking. What colour is the smoke? How fresh is the fuel? Did you use the Deere manual to time the cam and pumps?
