830 vs 300ind
carl
11-12-2003 17:27:53
I've owned a 300industrial for several years. I recently bought a 830 3 cyl with a loader. My mechanic claims the 830 is garbage and has totally oddball parts because of its european heritage.Why would it inferior to an american built one? Is there any parts problem? Can someone explain why it is different?
Dale in IN
11-13-2003 06:17:54
 Re: 830 vs 300ind in reply to carl, 11-12-2003 17:27:53
Carl:
I have a 1975 830 D That I purchased new in 1977. It is one of the best buys that I have ever made.It is one of the biggest litle tractors ever built. It now has over 6600 hrs on it and still going strong. I pull a 7000 6 row dry fert planter. a 6 row danish tang cult. a 9' hay bine and a 14T bale with a wagon behind with a capacity of 120 - 150 bales. It also has a #143 loader on it. Have had no trouble getting what few parts I have needed from J D Dealer.
AS for as the 300 Industrial, I have one of those also. Set them side by side and they are very simular. The 300 is built heaver in the front end with a cast Iron front plate and a heavier axle. My 300 has the shuttle clutch and the gear shift pattern is the same. The 300 has a #7 loader and a #92 back hoe on it. The hydraulic pump on the 300 has a greater capacity and is of a different make.
The 830 pump is a double pump and 1 end is for the power steering and the other runs the hydraulics.
Your mechanic apperantly has not been around many 830'S.
