John Deere B 1950 Rocker arms
Bill Hecker
11-03-2000 04:59:47
Does anyone know why the rocker arms work one time when I press the pedal and then fail to work the next 6 or 8 times I press the pedal? THANKS..... .
Bill Hecker
11-06-2000 07:51:53
 Re: John Deere B 1950 Rocker arms in reply to Bill Hecker, 11-03-2000 04:59:47
I have found the answer to the problem. It was a
linkage problem. The trip lever did not return to
the bottom far enough for it to click into the next notch on the internal shaft that causes the valves to open and close as it revolves when push
ed by the foot pedal. THANKS for the replys
JimA TX
11-03-2000 14:31:32
I still don't know what you are talking about. The 1950 Movel B does not have a pedal. The rockshaft is activated by a lever on the left side of the seat.
DP
11-03-2000 20:48:59
 Re: Re: John Deere B 1950 Rocker arms in reply to JimA TX, 11-03-2000 14:31:32
On all B's, power lift was optional, and powr-trol was another option. They had the basic pedal kick lift as the cheapest lift system. On the late B's, there was just one pedal, and it came out from under the battery box right in the center.
KH
11-03-2000 12:51:01
I think you mean the rockshaft not the rockerarms. It could be low on fluid or maybe the peddals aren't coming all the way back up after being pushed down.
KH
11-03-2000 12:47:46
I think you mean the rochshaft not the rockerarms.
It might be low on fluid or maybe the peddals aren't coming back up all the way after you push them down.
