John Deere Flywheel Wrench???
Donny-B
11-01-2000 17:14:16
I recently purchased a wrench that was suppose to be a John Deere flywheel wrench. Upon inspection it has no JD markings. The only marking is "Made in USA". The wrench is a boxed end with 1 1/4" and 1 1/16 ends measuring about 19 1/2" long. The main body is straight and the ends are at about 15 degrees. There was traces of green paint on it. Could this be an original or is it a copy? What I want is a Flywheel Wrench for a 41 John Deere H. Thanks!
Jason in Ohio
02-20-2006 17:52:14
 Re: John Deere Flywheel Wrench??? in reply to Donny-B, 11-01-2000 17:14:16
Anyone have a flywheel wrench for a JD D. I am looking for one and have been unsuccessful at obtaining one. Thanks
Jason
Mike in Mo
11-05-2000 08:57:30
I bought what is supposed to be an "A" flywheel wrench, but I have yet to figure out what position toput the flywheel in to use it.Anyone with some insight? Maybe the one I have isn't for an "A".
Shorty Dear
11-05-2000 14:40:52
 Re: Re: John Deere Flywheel Wrench??? in reply to Mike in Mo, 11-05-2000 08:57:30
Mike,
What does your ???flywheel wrench look like? The correct one is about 12 inches long overall, and is shaped nearly like an S. It has 2 ninety degree turns in it. It has an 1 1/4 inch socket on one end and a big hex nut on the other. I have these wrenches for sale.
ellis brasher
07-14-2003 17:21:55
 Re: Re: Re: John Deere Flywheel Wrench??? in reply to Shorty Dear, 11-05-2000 14:40:52
I have one that a friend gave me about 5 years ago. It is a box on each end, about 16", and rather straight with JOHN DEERE written in bold letters, The big end is 6 point, 1 1/4" and the little end is 1 1/16" 12 point. I have a 520 and a 730 both factory propane that I use 2-3 times weekly.
I know how to fix messed up flywheel and crank splines if anyone wants to know.
Donny-B
11-02-2000 19:26:46
Thanks a bunch guys. I need all the help I can get on these green machines.(use to be a red man) I'm sure I'll have more questions as I get more involved in rebuilding my little H "Johnny Popper."
Deerejon 2000
11-01-2000 20:02:21
The wrench you purchased sounds like the original wheel wrench JD supplied with a "G". We had one of these, ours had a round shaft. We also made our own flywheel wrench. It was a squared U, one leg was shorter than the other, about 3"long. We welded a 1/2" square to the short leg so we could use different sockets for different tractors. We used a piece of pipe on the longer leg for leverage, a longer pipe for a bigger tractor. : )
clooney
11-01-2000 17:54:36
third party image
Donny, the H flywheel wrench should look like this.
Tugboat
11-02-2000 04:08:01
 Re: Re: John Deere Flywheel Wrench??? in reply to clooney, 11-01-2000 17:54:36
Clooney; I'm impressed. You always seem to have the right answer! Good to see that you are still participating in the Forums! Regards; Tugboat
Dan
11-01-2000 17:42:54
There were different wrenches for each tractor as the bolts were differnet sizes. Don't know that I ever saw a real JD flywheel wrench, just ones that were made up to do the job. The one I have was my dad's, he worked on JDs for about 28 years as a job, about 81 years total. Think it is for an A or G. I'm not sure of the socket size but it comes up a short distance, makes a right angle a few inches and another right angle. The H has less width to the flywheel so you probably wouldn't need asl long of extension on it.
