Carb Model H JD
Frank
10-31-2000 15:19:05
I have the DLTX-26 carb off of my 39 H. The flange that bolts to the manifold has been welded (very ugly weld). I was planning to rebuild the carb but I'm not sure it's worth it. Everything in it is rusty. How about it? Should I rebuild it or find a better one? Thanks in advance
Frank
clooney
10-31-2000 15:28:01
 Re: Carb Model H JD in reply to Frank, 10-31-2000 15:19:05
Frank, it depends on what you want to spend. You can probably grind that ugly weld down & start over. (I have done a couple re-welds on poor carb flange repair attempts & had very good success, I grind them down then re-weld then grind again then go over the weld area with an air powered needle de-scaler to roughen up & make look like casting then sand blast)..... You can try "Roberts Carb Repair" to see what he would charge to repair or replace.
Frank
10-31-2000 15:42:34
 Re: Re: Carb Model H JD in reply to clooney, 10-31-2000 15:28:01
Thanks, Clooney. I've already bought a kit but I think I'll give Robert's a call. I'd rather let a professional handle this.
By the way, the wheels turned out great.
clooney
10-31-2000 17:22:08
 Re: Re: Re: Carb Model H JD in reply to Frank, 10-31-2000 15:42:34
Frank, glad to here the rim replacment went good. Did you have any trouble setting the rivets?.... If you decide to buy a new (used) carb, a DLTX 46 will work good also, you will have to use the choke shaft & lever from your DLTX 26 (non choke rod type) the 46 choke will work ok but looks funny on a hand start.
Frank
10-31-2000 18:30:58
 Re: Re: Re: Re: Carb Model H JD in reply to clooney, 10-31-2000 17:22:08
The only trouble I had was my little air compressor wasn't big enough to run the air hammer for very long. I did one thing different. while the guy was here making the spot welds, I had hin use his torch to cut small holes for the rivets. Then I used a drill to make them round. The only railroad iron I could get my hands on was about 6 ft. long. No problem, I used the bed of my pickup for a workbench. Thanks for the information.
