4020 Side Frame Rails
Tom P
10-30-2000 11:20:38
I need to replace the hydraulic line that runs to the pump behind the left side frame-rail on my 4020. Do I need to support the tractor someway before I loosen the frame-rail enough to install the new line?
Thanks for the help
GregA
10-31-2000 19:37:11
 Re: 4020 Side Frame Rails in reply to Tom P, 10-30-2000 11:20:38
Good luck getting the fittings broke loose by the pump. Mine were rusted and there isnt much room to get a wrench in.
Jiff
10-30-2000 13:55:52
If I remember right, place a jack and block under the oil pan, and just jack it enough to put a slight bind on everything. It isn't that big a deal. If the fittings are real tight, which they will be, take a punch and hit the flats of the hex, and they will come off easier. Also, if I remember right, the frame rails should be torqued to 400 Lb. Ft., as the bolts are special tapered head ones.
david val
10-30-2000 21:00:33
 Re: Re: 4020 Side Frame Rails in reply to Jiff, 10-30-2000 13:55:52
5/8" bolts should be tightened to 275 ft/lb. retighten after a few hours of use.
david
