I called Don Ward who is listed in 2-cylinder as available to answer technical questions about 70's and diesels. He said he's never seen a differential that wouldn't go in if positioned just the right way, but that some are very close.But I now have both bearings pulled, and even with the spur gears removed completely, the shaft with only the ring gear attached will just not go in, no matter how it is handled. Seems like the only thing left to do is press out the shaft, heat the ring gear in an oven, put it in the case and then slide the (cold) shaft through from the right, which requires pulling the reduction gear cover! But they can't possibly have done this on the production line, could they? Anyone who has ever done this on a 70D *please* contact me and tell me how you did it! Others have done it on other 2-cyls. but maybe they aren't as difficult... if I ever get it done I'll post the secret. Thanks!
