2120 Update
Paul
10-28-2000 22:06:36
The 2120 I asked about sold at auction for over $8500 (had a JD loader on it). I thought that a little (lot) too high, given it had 40% - 50% rubber (rear) and corrosion was very evident around the perimeter of each rear wheel. I wonder if they put one of those corrosive calcium liquid compounds in the wheels for weight? One thing I questioned, is that the PTO was constantly turning: moving the PTO lever would not, seemingly, engage or disengage it. One gentleman looking at the tractor thought this not unusual, since he thought it might need to have an implement attached in order to come to a complete stop. Anybody have any thoughts on that?
W C Smith
04-30-2005 19:44:02
 Re: 2120 Update in reply to Paul, 10-28-2000 22:06:36
I have a John Deere 2120 and most of the time the PTO is turning. I have adjusted the lever several times but the PTO keeps turning. The Only way I can make it stop is by applying pressure to it with my boot.
Can you tell me where I can find an oil bath for it or what I can replace the oil bath with?
kylesjones
09-19-2004 10:57:44
i have a 2120 and the shaft is not suppose to turn until you engage it. it is not suppose to turn at all.
william
10-29-2000 08:12:41
have 2020 the pto turns disengaged especailly cold...you can take your hand and stop it ,,it is just friction turning
Paul
10-29-2000 19:34:16
 Re: Re: 2120 Update in reply to william, 10-29-2000 08:12:41
Couldn't take your hand, or boot, and stop this one; we tried.
G Taylor you did what?
10-29-2000 19:55:06
 Re: Re: Re: 2120 Update in reply to Paul, 10-29-2000 19:34:16
Is it a good idea to grab a grooved rotating shaft connected to a four cylinder diesel just to see what happens?
