JD 530 Power Shaft (PTO) linkage adjustment
Larry
10-28-2000 12:03:23
Since I purchased this 530 the power shaft clutch pedal has not latched. It does not latch in the off (down) position or the engaged position. I have adjusted the clutch, shortened/lengthened the lever rod -- all to no avail. Somehow I think that slotted plated down on the pivot pin at the foot lever has something to do with it but I guess I am not smart enough to figure it out. What keeps this pedal locked into position without having to keep your foot pushing on it all the time?? Any help would sure be appreciated. I have followed the instructions in the JD 530 service manual as to adjustment of the clutch but it does not address the foot-pedal locking problem. Thanks again.
Art Crawford
10-29-2000 06:42:33
 Re: JD 530 Power Shaft (PTO) linkage adjustment in reply to Larry, 10-28-2000 12:03:23
The power shaft stays locked into postion internal to the clutch in the case. Disconnect the linkage at the lever arm - now engage the power shaft using only the lever arm (may need extra muscle). If you can feel it snap into the locked in postion you can now reattach the linkage and try to make it fit. I rebuilt mine (clutch) and it took me several trys to get it to lock into place. Had the shaft out several times - I think I had to lock it into place on the bench.
Good luck - send mail if you specific question.
Art
