4620
540PTO?
Todd
10-28-2000 08:06:06
I recently purchased a jd 4620. It has a
1,000 PTO...can I put a 540 PTO on it?
Also, the brakes are extremely sensetive
we u touch them they lock up.
Is this likely adjustment or something more
serious?
Any and all input appreciated.
Thanks
Jon
10-27-2003 15:47:12
 Re: 4620 - 540PTO? in reply to Todd, 10-28-2000 08:06:06
4620 and 4520 are 1000 rpm PTO only, But you can buy an external gear box to run a 540 RPM. There are around $1225.00 From HUB CITY ACCESSORIES. They are rated to 125hp which is a little short of the 4620 136+hp. The 4520 are rated to make 123+hp... The diesel shop that rebuilt my injector pump said it wasn't unsualy for a 4520 to make 160+hp.
G Taylor check trans oil for metal fileings
10-29-2000 20:00:02
If the ordinary gear lube has been added to the transmission oil or if somebody has been using the brake pedals as a foot rest the brake linings maybe gone. Metal to metal contact will grab & squeal.
JDGnut
10-28-2000 16:12:34
All of the 4620 only had the 1000 PTO and I have never seen an aftermarket conversion for something like this, It will probably be easier to change your implement.. On the brakes, there is no Adjustment.
JDGnut
