Sediment bulb shut off valve
AS
10-27-2000 08:16:59
How do I get the shut off valve on the sediment bulb to seal when I shut it off? I have taken it apart and there are no rubber seals where the turn valve is, just a copper plug with a hole in it. I can shut the tractor off this way, but over a couple of days gas will leak past and into the carb. Thanks.
Dick Cumiskey
10-27-2000 08:59:48
 Re: sediment bulb shut off valve in reply to AS, 10-27-2000 08:16:59
Short of having the components plated, then re-machined for a tighter fit, your only choice is to replace the entire unit with an aftermarket valve using a rubber type compression seal.
