420 belt
mr. green genes
10-26-2000 16:46:19
I have a 420 engine in an M and don`t have a clue on how to adjust or replace the water pump belt.I started to take off the radiator but can`t even do that without taking off the bracket that holds the hood on. Just thought there must be an easier way.Any ideas would be appreciated.
Prune Picker
10-26-2000 17:12:19
 Re: 420 belt in reply to mr. green genes, 10-26-2000 16:46:19
My 420 has a set screw on the water pump pulley. Loosen the screw slightly and place a piece of wood against the square shoulders located at 90 degrees around the pulley. Strike the wood with a hammer. This will turn the pulley on the shaft threads, shortening the width between the front and back of the pulley (which tightens the belt). Tighten the set screw and you are done. Check after running to make sure the set screw hasn't loosened up, which they sometimnes do.
